txskywtchr's avatar
txskywtchr
Follower
Mar 21, 2023
M6 Pro GPS
Hello,
I’ve enabled GPS on my M6 Pro, but my laptop isn’t reading the data. I also have a GPS Splitter, but it cannot connect to the host or port 5502. Any ideas?
1 Reply
  • Hi, it sounds like the GPS data from your M6 Pro isn’t reaching your laptop, possibly due to a connection or configuration issue. First, make sure your GPS Splitter is correctly configured to receive data from the M6 Pro and is set to forward it to port 5502. Also, ensure no firewall or antivirus is blocking the connection on that port. If the splitter can’t connect to the host, double-check the IP address and port settings. Restarting both devices can also help re-establish the connection.
