BartMel
Feb 02, 2023Tutor
M6 Pro (MR6450) supported band combinations
Hi, From the datasheet of the M6 Pro, it seems that B40 LTE and n78 NR is supported, but is the band combination B40/n78 supported for use in a 5G NSA network? Also, are there any restrictions ...
Blanca_O
Feb 08, 2023NETGEAR Employee Retired
Hi BartMel
NETGEAR has several different SKUs of the Nighthawk M6 Mobile Router products and each product has a specific set of bands that is supports based on the region that it is purchased in.
Kindly check this KB link: https://kb.netgear.com/000065402/
Blanca
Community Team
JohnPeng
Feb 15, 2023NETGEAR Expert
B40+n78 is supported on the SKU and also the device support SA mode for all NR bands.
Thanks
John
