charchi
Aug 21, 2024Follower
M6 pro (MR6500-1TLAUS) firmware
Hi I have a M6 pro (MR6500-1TLAUS) from Telstra with current firmware NTGX65_12.01.41.00 Can someone kindly confirm what the latest firmware is for this model? (according to update via route...
Blanca_O
Aug 27, 2024NETGEAR Employee Retired
Hi charchi,
The Nighthawk M6 Pro automatically checks for new software or firmware updates periodically. If an update becomes available, the Nighthawk M6 Pro displays an alert. There is no option to manually update the firmware as it is locked by the Internet Provider.
Blanca
Community Team
- pm_2024Nov 06, 2024Aspirant
Good Day
I have an AT&T unlocked M6 Pro. Has there been any other changes to allow for a firmware update to the device. I am presently outside of the United States.
Please advise
- rcpaxNov 06, 2024Luminary
pm_2024 wrote:Good Day
Please advise
No there will not be any change to allow you to update the firmware of your device unless you are on the ATT network, using an ATT sim card. The firmware updates are provided by ATT. Netgear does not provide firmware updates to ATT branded devices directly, updates all come from ATT servers
