mactrick
Nov 05, 2022Aspirant
M6 Pro (MR6500) Offload Losing Internet
I have a Nighthawk M6 Pro that is set up to offload internet to a Starlink router with AT&T data plan for standby. I’ve tried both WiFi and Ethernet offloading to Starlink, but in both scenarios the I...
- Dec 12, 2022
mactrick wrote:
Hello JohnPeng,
Any update on this issue?
Could you please try with the latest AT&T release that went public recently? Please let me know if you still see the offloading data link failure.
I saw the issue couldn't be reproduced in our internal testing using the latest release.
Thanks
mactrick
Nov 08, 2022Aspirant
Thank you for your help JohnPeng
UPDATE --
Results using WiFi Offloading and running continuous ping:
- Successful ping with intermittent timeout (Average 7 successful to 1 timeout) for about 40 minutes, then it became unstable --
64 bytes from 142.250.72.174: icmp_seq=1191 ttl=57 time=290.404 ms
Request timeout for icmp_seq 1192
Request timeout for icmp_seq 1193
Request timeout for icmp_seq 1194
Request timeout for icmp_seq 1195
Request timeout for icmp_seq 1196
Request timeout for icmp_seq 1197
Request timeout for icmp_seq 1198
Request timeout for icmp_seq 1199
Request timeout for icmp_seq 1200
Request timeout for icmp_seq 1201
Request timeout for icmp_seq 1202
Request timeout for icmp_seq 1203
Request timeout for icmp_seq 1204
Request timeout for icmp_seq 1205
Request timeout for icmp_seq 1206
Request timeout for icmp_seq 1207
64 bytes from 142.250.72.174: icmp_seq=1208 ttl=57 time=63.441 ms
Request timeout for icmp_seq 1209
64 bytes from 142.250.72.174: icmp_seq=1210 ttl=57 time=49.543 ms
64 bytes from 142.250.72.174: icmp_seq=1211 ttl=57 time=117.613 ms
Request timeout for icmp_seq 1212
64 bytes from 142.250.72.174: icmp_seq=1213 ttl=57 time=111.014 ms
64 bytes from 142.250.72.174: icmp_seq=1214 ttl=57 time=169.441 ms
64 bytes from 142.250.72.174: icmp_seq=1215 ttl=57 time=190.976 ms
Request timeout for icmp_seq 1216
Request timeout for icmp_seq 1217
This continued for a few minutes, and finally:
ping: sendto: No route to host
JohnPeng
Nov 08, 2022NETGEAR Expert
Thanks for the quick update. I will check with the team what will be the next steps to debug the issue.
Just want double check, you wouldn't see the issue when you connected the WiFi devices directly to Starlink WiFi router.
Thanks
- mactrickNov 08, 2022Aspirant
Correct. I do not lose Internet connectivity when connecting to Starlink WiFi Router.
- JohnPengNov 08, 2022NETGEAR Expert
Seems we can reproduce the issue internally with WiFi and ethernet offloading. The data connection got lost after about an hour. A ticket has been created to have the issue addressed asap,
Thanks
