hkm5007
Oct 06, 2023Tutor
M6 pro mr6500
Is the support of the bands through the firmware of the system or through the hardware, meaning, is the American version of it working in Europe if the sku changes from nas to eus?
michaelkenward
Oct 06, 2023Guru - Experienced User
Are you asking about changing the region for the wifi?
Not sure about mobile devices like the M6, but Routers sold as NAS seem to be locked down whereas European devices let you change the region.
So it may be a mix of hardware and firmware. My guess is that the hardware is the same but the firmware is locked. There used to be "command line" (Telnet) ways to get around this. But newer routers don't have that option.
- hkm5007Oct 06, 2023TutorPlease, if you are from the technical support for the devices, make sure of this point for me.
In the sense that the NSA can be changed to EUS on the version of mr6500
And he works without any problems?- michaelkenwardOct 06, 2023Guru - Experienced User
hkm5007 wrote:
Please, if you are from the technical support for the devices, make sure of this point for me.You should know that this community is essentially a user-to-user venue to talk about technical issues, with some input from a small band of Netgear techies.
Most of the answers come from fellow users who have no connection with Netgear. They just have a lot of collective experience and are familiar with the sort of problems that turn up here.
They aren't equipped to answers sales questions or to talk about warranty issues.
If you want "official" support then you should go through the right channels.
