JKYoo
Aug 09, 2023Follower
M6 pro MR6550 5g not working in South Korea
Hello, everyone I recently bought an unlocked MR6550 from Amazon. When I connected to the mobile Internet with a SIM, only 4G is connected, and 5G is not connected. I am currently using the MR6...
ecofri
Oct 26, 2023Guide
Did you solve the problem?
To enable 5G connectivity, SKTelecom requires device registration. (5G-OMD)
JohnPeng
Oct 26, 2023NETGEAR Expert
Do you know what 5G bands are used in SKTelecom?
Thanks
- ecofriOct 26, 2023Guide
All three cellular carriers use N78 for their 5G services.
SKTelecom
LTE: B1, B3, B5, B7
5G: N78
Korea Telecom
LTE: B1, B3, B8
5G: N78
LG U+
LTE: B1, B5, B7
5G: N78
I want to use MR6550 in Korea, but I want to be sure 5G can be enabled before buy it.
- JohnPengOct 26, 2023NETGEAR Expert
Yes. I can confirm that MR6550-100PAS supports n78. This band is used in Canada as well.
Thanks
Thanks for the confirmation.
MR6550 supports nearly all popular 5G bands in the world.
What about EN-DC or carrier aggregation?
Does it support any kind of carrier aggregation involving NR78 ?
B1+3+5+7 + NR78
B1+3+7 + NR78
As far as I know, SKTelecom's 5G network works in non-standalone mode, so band aggregation should be supported to enable 5G data connectivity.
