JKYoo
Aug 09, 2023Follower
M6 pro MR6550 5g not working in South Korea
Hello, everyone I recently bought an unlocked MR6550 from Amazon. When I connected to the mobile Internet with a SIM, only 4G is connected, and 5G is not connected. I am currently using the MR6...
JohnPeng
Oct 26, 2023NETGEAR Expert
Do you know what 5G bands are used in SKTelecom?
ecofri wrote:
Did you solve the problem?
To enable 5G connectivity, SKTelecom requires device registration. (5G-OMD)
Thanks
ecofri
Oct 26, 2023Guide
All three cellular carriers use N78 for their 5G services.
SKTelecom
LTE: B1, B3, B5, B7
5G: N78
Korea Telecom
LTE: B1, B3, B8
5G: N78
LG U+
LTE: B1, B5, B7
5G: N78
I want to use MR6550 in Korea, but I want to be sure 5G can be enabled before buy it.
- JohnPengOct 26, 2023NETGEAR Expert
Yes. I can confirm that MR6550-100PAS supports n78. This band is used in Canada as well.
Thanks
- ecofriOct 26, 2023Guide
Thanks for the confirmation.
MR6550 supports nearly all popular 5G bands in the world.
What about EN-DC or carrier aggregation?
Does it support any kind of carrier aggregation involving NR78 ?
B1+3+5+7 + NR78
B1+3+7 + NR78
As far as I know, SKTelecom's 5G network works in non-standalone mode, so band aggregation should be supported to enable 5G data connectivity.
Looks like the band support in South Korea is the same as EU. Since you are not going to use mmWave, I think it is better you get the MR6450-100EUS. That will support the EN-DC as you listed for sure with n78.
MR6550-100PAS is targeting US and Canada. Roaming band and combos support will be limited for EU countries.
Thanks
