nastor5
Jul 01, 2023Follower
M6 Pro MR6550 Faulty Power Adapter
I got a M6 Pro Unlocked MR6550 for a US colleague, and when using the original power brick and cable, the nighthawk doesn’t boot and says “use the supplied power adapter when operating without batter...
JohnPeng
Jul 03, 2023NETGEAR Expert
nastor5 wrote:
I got a M6 Pro Unlocked MR6550 for a US colleague, and when using the original power brick and cable, the nighthawk doesn’t boot and says “use the supplied power adapter when operating without battery”. Which is funny because it is the original power adapter and cable.
I’m getting a new power adapter from Netgear, but I’m curious:
Could someone do me a slot and send a pic of their M6 Pro US power adapter. Specifically the text part that has the input output info.
Has anyone experienced this?
Sent PM to you. Please check. I would like to get your set of USB cable and PA back to check.
Thanks
John
JohnPeng
Jul 07, 2023NETGEAR Expert
Could you please check your PM and reply to me?
Thanks
John
- ASG2662Jul 17, 2023Initiate
I'm having the same problem as well. Seems like the OEM charger isn't giving the output required. Please advise.
- JohnPengJul 17, 2023NETGEAR Expert
Could you please detail what is the issues you are experiencing with the PA or USB cable?
1. Are you using the device without battery or with battery?
2. The device can't be charged or slow to charge?
3. Have you confirmed this is PA issue or USB cable issue?
Thanks
- liviuxJul 31, 2023Aspirant
Same here. My M6 worked fine until this weekend when I applied the latest update to it. It rebooted a few times through the update process. Now that the update is in place, it gives the same message "Use the supplied power adapter when operating without battery" If I put the battery in, it does start, but does not seem to be charging. Very frustrating.
