gullies1101
Feb 10, 2025Aspirant
M6 screen icon meanings
Dumb question but buggered if I can find a reference to the M6 hotspot screen icons and their meanings in the manual or on the web. My M6 suddenly started displaying a red triangle with an exclamati...
- Feb 11, 2025
Have you tried accessing the webGUI and see if the error appears? Might also help if you take a pic to the actual LCD display next you see this message and post here. that will help other be aware of this mysterious error message. I would also assume you have it on the latest FW?
rcpax
Feb 11, 2025Luminary
Swipe up on the screen. Usually the error message will pop-up. The only time I saw a red exclamation error was for an overheat situation. It will go away once the device cools down.
gullies1101
Feb 11, 2025Aspirant
Thanks for your reply.
I run the M6 without the battery so heat shouldn't be a factor. Having said that I do live in Queensland Australia and it is warm/hot here.
The small red triangle is on the "front" page of the device with the time, signal strength, etc. Swiping up doesn't pop up the error message.
It is nice of Netgear to have no reference to this icons anywhere..... NOT
cheers
- rcpaxFeb 11, 2025Luminary
- gullies1101Feb 11, 2025Aspirant
Image as suggested attached
Please excuse all the reflections but was just a quick shot
Image not loading on my end.
