gullies1101
Feb 10, 2025Aspirant
M6 screen icon meanings
Dumb question but buggered if I can find a reference to the M6 hotspot screen icons and their meanings in the manual or on the web. My M6 suddenly started displaying a red triangle with an exclamati...
- Feb 11, 2025
Have you tried accessing the webGUI and see if the error appears? Might also help if you take a pic to the actual LCD display next you see this message and post here. that will help other be aware of this mysterious error message. I would also assume you have it on the latest FW?
Electron55
Mar 08, 2025Aspirant
I also have the same icon appear on my screen, it is there all the time, there are no error messages. So what does it mean. I can see the images of the other poster.
gullies1101
G'Day
I am still trying to find out what that icon warning is. No one seems to be able to give me an answer. The interesting thing is it doesn't seem to have affected the modems performance (that i can tell anyway!).
My research continues but am very interested if anyone (including Netgear support) has an explanation.
- Electron55Mar 08, 2025Aspirant
Doing a bit more research, there has been a mention that it is a high temp warning. When my unit is turned on in the morning it works very well, but as the day goes on the unit gets hotter and the performance drops off. It use to lay on a shelf, but now it sits vertical on brackets a few cm from the wall. It takes longer to heat up and good performance lasts longer. That warning triangle stays on all the time, it is there when first turned on.
- gullies1101Mar 08, 2025Aspirant
My modem is on power WTHOUT the battery, or rear cover, fitted. I have rigged a platform which allows it to sit an inch or so above my ethernet switch and allows air to flow through. It is also near a windows. Admittedly I live in central QLD Australia which is sub tropical/tropical and the weather is warm/hot. At the moment the device temp reports 56c so that maybe it but it has never shutdown or reported temp problems. I am a retired computer tech and all my computer equipment never complains of heat. I have a lot of hifi and electrical musical equipment that never suffers from heat problems.
