Brabb12
Nov 17, 2023Aspirant
m6500 usb tether to ASUS 1900 router
Hi there. First time posting. I looked around but didn't find what Im looking for.
I just got the m6500 unlocked unit. Im using it with T-mobile's network.
I want to usb tether the m6500 to my asus 1900 router.
I have tried to get it to connect but no luck with it.
Usually with the ASUS 1900 its very simple of a plug in and switch the connection over from ethernet cable to usb tethering. (using the ASUS firmware)
Before the m6500 I was using a franklin T9 to usb connect to the ASUS router with no issues.
Any advice on what I need to do to make this connection work?
Go easy on me, im new to this device.
Brandon
No RepliesBe the first to reply
