GDSR5
Aug 16, 2025Aspirant
M7 Ultra Pro - external antenna
With the M7 Ultra diesel the modem transmit wifi signal from the external antenna or just receive signal. I have a M7 in a locked container and would like to receive 5g signal and transmit a wifi sig...
- Aug 18, 2025
TX and RX - but only for the mobile network,, including 5G services - not for the WiFi.
rcpax
Aug 21, 2025Luminary
just to clarify what was already stated, the external antenna ports on the M7 is for 5G/LTE radio, not for WiFi. WiFi signals are sent and received via internal antennas in the device and there is no external port for you to connect WiFi antennas.
