GDSR5
Aug 16, 2025Aspirant
M7 Ultra Pro - external antenna
With the M7 Ultra diesel the modem transmit wifi signal from the external antenna or just receive signal. I have a M7 in a locked container and would like to receive 5g signal and transmit a wifi sig...
- Aug 18, 2025
TX and RX - but only for the mobile network,, including 5G services - not for the WiFi.
Sep 26, 2025Guru - Experienced User
Yes, ethernet and wifi work at the same time. If it was me? I'd just connect a access point to it. Or you could use a full router and put the M7 in passthrough mode. Both options would work. Metal containers are great at blocking wifi. (and trapping heat, might need a vent if its a small container)
