Roo23's avatar
Roo23
Manual band selection nighthawk m2
Can you manually set the M2 to fix on a specific band / 4g mast? Mine automatically goes for the nearest but it’s not the fastest. I will attach a directional antennae but don’t want it to flick between the two.
  • You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
    You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Mobile Routers, Hotspots & Modems
    These are very different devices.
    I have asked the Netgear moderator to move your message.
