B0st0nG30rg3's avatar
B0st0nG30rg3
Follower
Oct 27, 2022
MBRN3000 3G issue
Hi All, my mbrn3000 is using 3g network with USB stick plugged into. Some times 3G connection drop and led come Red. In this scenario, the router don't try to restore 3G connection the only Solution is to reboot router.
My mbrn3000 is updated to The last firmware available, any suggestion?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Not your average router. So not something likely to be familiar to people who visit this section.
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Mobile Routers, Hotspots & Modems
    Those things are very different from the standard Netgear routers covered in this section.
    You might like to search there for messages related to your problem.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
