Martin9426's avatar
Martin9426
Follower
Jan 13, 2015
MBRN3000 and Huawei e535 don't work?
Hi all.
I just got a new USB modem stick (Huawei e353 HSPA+) which I want to use with my 3G router (MBRN3000 with latest firmware, which should support this modem according to release notes).
However, despite the indicator lamp on the stick turning stable blue, the router setup page claims the modem is incompatible.
Any solutions for this????
1 Reply
  • Babylon5's avatar
    Babylon5
    NETGEAR Employee Retired
    You may need to edit the Access Number / APN / PDPD type in the Mobile Broadband Settings page, have you tried this already? Can you say who your provider is, the details required are most likely on their website.
