losminos
Feb 14, 2016Aspirant
MBRN3000 Unable to connect broadband network
Hallo I was using the MBRN3000 with ZTE MF652 3G USB stick. This one started to overheat and was disconnecting me from broadband. So I got my self a stick which is on the list of netgear MBRN300...
Retired_Member
Feb 15, 2016Did you try a factory default? Also can you verify the stick FW versions. Try updating it using PC.
losminos
Feb 18, 2016Aspirant
Hallo Thank you for answer.
On router side i tried everything. also factory default settings and newly configure WAN, LAN, Wifi...
Currently I am trying again with ZTE MF636. Again stick recognised by router but not possible to connect to broadband..
I am getting crazy.
Can you please advise me what to do with the stick firmware ?
I already bricked one (Huawei E169 - again supported by router, working but with extremly slow speed).
I checked by DC unlocker, both sticks are unlocked for all networks.
Searched on internet for something with firmware, but found nothing. just drivers for WIndows (which I dont need as stick works nicely on PC)
I am already getting crazy of it..
- losminosFeb 18, 2016Aspirant
update: ZTE MF636 cannot even find any network when connected on netgear router.
On PC everything works perfectly, connection is estebilished within seconds....
Bloddy crap this netgear router....
