John503
Jul 24, 2023Aspirant
Mesh System
Can I connect a mesh system to this mobile router..M6 Pro. I live in an area 5his is my only internet option Thank you
Jul 24, 2023Guru - Experienced User
Try AP mode on the MESH system.
What NG MESH system model do you have?
John503
I have not purchased one yet I am trying to see if it will work... I have no either net company just at&t m6 pro mobile for my wifi
- FURRYe38Jul 24, 2023Guru - Experienced User
The MRs already have a built in router, adding another can complicate things. If you need WIFI MESH for more wifi coverage, then Orbi or the Nighthawk MK MESH systems can be configured for AP mode for easier installation with MR mobile routers.
