John503
Jul 24, 2023Aspirant
Mesh System
Can I connect a mesh system to this mobile router..M6 Pro. I live in an area 5his is my only internet option Thank you
John503
I have not purchased one yet I am trying to see if it will work... I have no either net company just at&t m6 pro mobile for my wifi
Jul 24, 2023Guru - Experienced User
The MRs already have a built in router, adding another can complicate things. If you need WIFI MESH for more wifi coverage, then Orbi or the Nighthawk MK MESH systems can be configured for AP mode for easier installation with MR mobile routers.
- John503Jul 24, 2023AspirantPerfect I will get one thank you. I just need the signal stronger to go around the house
- John503Jul 24, 2023AspirantAny suggestions for 3000 sqft house... I am not very versed in this stuff... thank you
- michaelkenwardJul 25, 2023Guru - Experienced User
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
