Patatorz
Feb 20, 2026Star
MH7150 M7 not accepting my eSIM
Hello, just bought a M7 to use a eSIM from Free (working fine on my iPad Pro). Whatever with QR code or manual configuration, the installation of the eSIM is not working. i would like to use it acco...
Feb 20, 2026Guru - Experienced User
Not all sims support hotspot plans. Some only work with phones/tablets. Did you check with Free to see what they support with their plans?
