Patatorz
Feb 20, 2026Star
MH7150 M7 not accepting my eSIM
Hello, just bought a M7 to use a eSIM from Free (working fine on my iPad Pro). Whatever with QR code or manual configuration, the installation of the eSIM is not working. i would like to use it acco...
FinnJacks
Mar 05, 2026Aspirant
Hi,
If your eSIM works on your iPad Pro but not on the M7, the issue is usually related to eSIM compatibility or carrier support rather than the QR code itself.
A few things you can check:
- Carrier compatibility – Some eSIM profiles from Free are optimized for phones/tablets (like iPad) and may not activate on other devices such as the M7.
- Device eSIM support – Even with the latest firmware, some devices only support specific eSIM providers or data-only profiles.
- Try manual activation again – Remove any previous failed profile, restart the device, and scan the QR code again.
- Contact Free support – Ask if the eSIM profile is compatible with the M7 device type. Some carriers lock profiles to certain device categories.
If the eSIM works perfectly on your iPad but fails on the M7, it’s very likely a device compatibility limitation with the carrier profile rather than a configuration mistake.
