Patatorz
Feb 20, 2026Star
MH7150 M7 not accepting my eSIM
Hello, just bought a M7 to use a eSIM from Free (working fine on my iPad Pro). Whatever with QR code or manual configuration, the installation of the eSIM is not working. i would like to use it acco...
HARRYHERE
Mar 07, 2026Aspirant
Hi Ludovic,
If your M7 isn’t accepting the Free eSIM, try these:
- Make sure the M7 supports the required eSIM profile and bands.
- Double-check the QR code or manual configuration.
- Try resetting the network settings or doing a factory reset.
- Confirm with Free that your M7’s IMEI is registered for eSIM activation.
Sometimes the carrier needs to push the eSIM profile to the device before it will activate.
