Patatorz
Feb 20, 2026Star
MH7150 M7 not accepting my eSIM
Hello, just bought a M7 to use a eSIM from Free (working fine on my iPad Pro). Whatever with QR code or manual configuration, the installation of the eSIM is not working. i would like to use it acco...
RSS7
Apr 14, 2026Guide
Hello, I have the exact same problem with my eSIM from Free (french operator).
When I try to add it via the NETGEAR App through the QRcode it fails, asking me to retry or cancel.
The other problem is that this eSIM (failed to be added) seems to keep one of the 7 eSIM "slots" in the router, with no way to delete it.
I tried multiples factory resets but it doesn't reset the eSIM chip
I hope for a NETGEAR firmware update that fixes those issues :)
