Patatorz
Feb 20, 2026Star
MH7150 M7 not accepting my eSIM
Hello, just bought a M7 to use a eSIM from Free (working fine on my iPad Pro). Whatever with QR code or manual configuration, the installation of the eSIM is not working. i would like to use it acco...
danieljocobsu72
Jun 03, 2026Aspirant
If the same eSIM works on your iPad, it’s likely a device or firmware compatibility/config issue on the M7 side, so checking carrier support for that model and re-provisioning the eSIM usually helps. Clear troubleshooting steps like this are easier to follow when well written, and tools like Corretor de Texto can help keep the details precise and structured.
