LuiVanning
Mar 15, 2022Aspirant
MIMO Antenna
Hello, I just bought a MIMO Antenna from Netgear, but my Wi-Fi router doesn't have the ts-9 connections,only USB. Do I have to get the Netgear router, or is there a way around it? I did some research...
Mar 15, 2022Guru - Experienced User
What model NG router do you have?
- LuiVanningMar 15, 2022Aspirant
it's not from NG, Glocalme LTE mobile Hotspot.
- CrimpOnMar 15, 2022Guru - Experienced User
That product cannot use external antennas.
- FURRYe38Mar 15, 2022Guru - Experienced User
Something to contact the Mfr of this device about regarding there product.
