LuiVanning
Mar 15, 2022Aspirant
MIMO Antenna
Hello, I just bought a MIMO Antenna from Netgear, but my Wi-Fi router doesn't have the ts-9 connections,only USB. Do I have to get the Netgear router, or is there a way around it? I did some research...
LuiVanning
it's not from NG, Glocalme LTE mobile Hotspot.
CrimpOn
Mar 15, 2022Guru - Experienced User
That product cannot use external antennas.
