jammer48
Feb 08, 2021Initiate
Mint mobile and Nighthawk M1
I have a mint mobile sim in my M1 but I can't get broadband connection. Not sure if my APN settings are correct. Any help would be greatly appreciated.
Japodac275
Sep 20, 2025Aspirant
Did you find a solution that works?
I’m running into the same issue
Sep 21, 2025Guru - Experienced User
I don't believe mint mobile supports hot spots. For a while, they'd had a "home internet" plan that was just a slightly cheaper version of tmobiles but I don't believe they off one themselves
