Dartthnog
Feb 07, 2025Follower
mobile app wont accept password for MR2100
I have a Netgear mobile router MR2100 and i am unable to access the app. It is asking for 'Mobile router's administration panel password. I have copied the password from the panel under the battery, but it wont accept.
I am trying to find out if there is an update for the firmware.
Any help would be much appreciated.
1 Reply
- rcpaxLuminary
Did you buy this new? If you did, I would assume you have changed the PW? Since you are having trouble logging in, I can also assume this might have been a refurb/used purchase as well where you were not given the non-factory admin password. In either case, your only way in is for a factory reset, if you really need to go into the admin UI, which as the owner of the device, that would have been the first thing I would have done. locate the physical reset button on the device, and try to perform a factory reset of the device. hopefully the reset button was not disabled as well, which in that case, you will not really have any other option to get in.
