Viro_Major
Oct 21, 2020Follower
Mobile broad
Hi all, new here I have a few questions regarding the MR2100 unit https://www.netgear.co.uk/home/products/mobile-broadband/mobilerouters/ Can it be plugged to a router and act like a 5G back...
Blanca_O
Oct 27, 2020NETGEAR Employee Retired
Hi Viro_Major
Welcome to NETGEAR Community!
If you plan to run the device 24/7, we suggest you to power the device with the PA only without inserting battery. This way, it will avoid the battery from getting hot and impacting the device's performance.
MR2100 does not have failover support.
https://www.netgear.co.uk/home/products/mobile-broadband/mobilerouters/M2.aspx
Blanca
Community Team
