yasop
Nov 07, 2013Aspirant
Mobile Broadband Aircard -> HSPA+ in 850 mhz, Low Strenght Signal Zones
I have the modem Aircard 312U and is the best I've tried so far. I wanted to know if there are others more powerful modems, or recommend a signal booster or antenna particularly powerful for weak si...
jmizoguchi
Nov 07, 2013Virtuoso
Not sure your question retains to netgear products unless you are using mobile broadband router from netgear
