yasop
Nov 07, 2013Aspirant
Mobile Broadband Aircard -> HSPA+ in 850 mhz, Low Strenght Signal Zones
I have the modem Aircard 312U and is the best I've tried so far. I wanted to know if there are others more powerful modems, or recommend a signal booster or antenna particularly powerful for weak si...
Gary_Y
Oct 19, 2014NETGEAR Employee Retired
In Australia, you can buy the AirCard 320U from Telstra that also does 3G 850MHz and 4G 1800MHz. Looks similar to the AirCard 312U but is a black USB modem.
Cheers!
Cheers!
