Cxris
Jan 22, 2020Follower
Mobile Broadband Disconnected Firmware 12.06.08.00
The new update caused "Mobile Broadband Disconnected" to show up on my router and now only connects to 3G on T-Mobile with no working internet. is anyone else having these issues?
JohnPeng
Jan 22, 2020NETGEAR Expert
Please advise the SKU name of your device.
Please provide some detailed information on the issue. When the issue happens, could you please help to capture a modem.json log for us to check?
Please follow the steps below:
Step 1: Open 192.168.1.1 on your browser.
Step 2: Input the account and password if necessary (admin/password)
Step 3: type 192.168.1.1/model.json
Step 4: Select everything (Ctrl + A), then copy-paste it into a text file.
Step 5: Save the text file as model.json_log.txt
Step 6: Submit the Log file
Thanks for your help on this.
If we have a fix for the issue, would you like to help us to verfiy?
- GPeoplesFeb 25, 2020Aspirant
SKU MR1100-100NAS
Can you help me get connected to the T-Mobile network. We reset the router with Netgear support and have a set APN to b2b.static.
Please see log file attached.
- Jpolitron14Mar 11, 2020AspirantWhere do we submit the log file?
- JohnPengMar 11, 2020NETGEAR Expert
Jpolitron14 wrote:
Where do we submit the log file?Please send a private message to me with the logs.
Thanks
- ken1944usMar 23, 2020Aspirant
Did you every get connected with T-Mobile?
- BrandidowdenMay 07, 2020AspirantI’m not tech savvy so don’t understand what ur saying to do. My nighthawk all of sudden say “mobile broadband disconnected” and I don’t think or know if it was because of an update. Is there somethin I can do? Or do I need a new sim ?
- RaineTensaiMay 07, 2020Tutor
I don't know if your situation is the same as mine, but I had an unlimited AT&T plan that had been grandfathered in, and was using it for my main source of internet. AT&T thought it was an ipad with an unlimited plan, but the sim card was actually in a mobile hotspot router. This worked for a long time. After much investigation, I learned that AT&T has been terminating these grandfathered accounts. It was nice while it lasted. I now pay twice as much for the same service.
