Cxris
Jan 22, 2020Follower
Mobile Broadband Disconnected Firmware 12.06.08.00
The new update caused "Mobile Broadband Disconnected" to show up on my router and now only connects to 3G on T-Mobile with no working internet. is anyone else having these issues?
Safwa009
Jan 26, 2020Guide
I am having the same exact issue with my M1
SKU: MR1100-1TLAUS.
FIRMWARE: NTG9X50C_12.06.08.00
- JohnPengJan 26, 2020NETGEAR Expert
You are using Telstra device. Could you please let me know which carrier you are using right now?
Thanks
- Safwa009Jan 26, 2020Guide
Saudi Telecom Company (STC)
Thanks for the information.
For your disconnection issue, please follow the steps below to check.
1. Contact the carrier to get the correct APN information and add it using WebUI.
2. If the correct APN has been correctly configured and the device still can't connect. Please make sure your SIM card can work in a phone
3. If Step 1 and Step 2 are all correct, most likely your carrier blocks the devcie to be used in their network. Please try a different carrier.
Regards
John
