Cxris
Jan 22, 2020Follower
Mobile Broadband Disconnected Firmware 12.06.08.00
The new update caused "Mobile Broadband Disconnected" to show up on my router and now only connects to 3G on T-Mobile with no working internet. is anyone else having these issues?
nickrod518
Feb 03, 2020Initiate
I have the same issue with my AT&T branded M1. I use T-Mobile and starting a few weeks ago it just stopped being able to connect to data. I verified the SIM works in another device and I even tried a different working T-Mobile SIM in the M1 and it gave the same behavior ("Mobile Broadband Disconnected"). I tried factory resetting the router and I even tried buying an identical replacement router and got the same issue. My router has SKU 6420B, Model MR1100-2A1NAS, and Firmware NTG9X50C_12.02.06.01. Would be awesome if whatever change was invoked by Netgear/T-Mobile could be undone as it's rendered my router useless.
JohnPeng
Feb 03, 2020NETGEAR Expert
This is really blocked by T-Mobile in your case. Our release doesn't block you to use AT&T or T-Mobile.
Thanks
