Barru21
Sep 08, 2025Aspirant
Mobile Broadband Disconnected M5
Nighthawk M5 5G WiFi 6 Mobile Router (MR5200) working but can't connect to data Your data connection is disconnected. Netgear support and the the provider Vodafone Support say all the se...
deuxcv
Sep 09, 2025Star
having similar problems with an m6pro. there is a separate thread about this. most or all of these folks are on att. the m6pro problem is linked to a software update friday night. unsure if it was netgear or att's update.
- Barru21Sep 10, 2025Aspirant
have you tride connecting to external erial?
