Barru21
Sep 08, 2025Aspirant
Mobile Broadband Disconnected M5
Nighthawk M5 5G WiFi 6 Mobile Router (MR5200) working but can't connect to data Your data connection is disconnected. Netgear support and the the provider Vodafone Support say all the se...
Barru21
Sep 10, 2025Aspirant
external antenna, I was lookingfor advise from a dutch Forum maybe they spell it that way`. I had no provider(vodafone) connection 4g / 5g. The connection returned after I attached the aerial connections which are 2 x TS-9 external antena connectors. (Not sure why I need 2 connectors)
But If I remove the connector for the aerial the operator 5g or 4g and bars are gone, no connection. And in the past it worked fine from the same location with no aerial connection.
