Ash1960
Jun 27, 2022Follower
Mobile Broadband Disconnected
Hi
After a thunderstorm the other night our Nighthawk device wont connect to mobile broadband, I've tried all the fixes suggested by Net Gear, I've rebooted umpteen times and checked all I can check etc. I've contacted Vodafone who assure me there are no problems on the SIM and if I try it in another mifi device it does work perfectly. Has anyone else any suggestions as to what I can try please?
Thank you
1 Reply
Ash1960 wrote:
After a thunderstorm the other night our Nighthawk device wont connect to mobile broadband....
Which Netgear device is that?
With all that stray electricity, thunderstorms are very good at wiping out electronic devices. Maybe you are another victim.
