1Vanglis
Dec 13, 2023Aspirant
Mobile Broadband Disconnected
Hello, I went to Verizon today and yesterday. We were faced issues with Mobile Hotspot related to the Internet Connection: Not Connected Go to Settings - Mobile * APN to confirm your APN settings (Er...
Draco_Dread
Mar 22, 2024Aspirant
Hello,
So I’ve updated to the latest version that was required to work with Verizon. I have the correct plan. Now I’m getting an error that says “Registration Error: There is a temporary network failure while handling a request from this device. Please try again later, or contact your service provider for help. (ESM #32)”. Talked to Verizon in person and they say there’s nothing wrong on their end. This error comes and goes randomly with sometimes rebooting the router fixing the issue until the next time I use it. Also seems that if I have a device that auto connects to the router when it’s booting up it will trigger this error as well. I will say for the price of this device to have this much issues is annoying. Any help with this new issue will be greatly appreciated. Thank you once again.
JohnPeng
Mar 22, 2024NETGEAR Expert
Draco_Dread wrote:
Hello,
Could you please advise which Pre-Paid or Post-Paid plan you got from Verizon? Did you get a brand new SIM card from BYOD portal or you just added the new plan to your existing SIM card?
Thanks
- Draco_DreadMar 22, 2024AspirantSo I have their 100gig at 80$ plan which you show as a pre-paid plan(store says they are post-paid plans since they are monthly subscriptions). The SIM card is brand new from the store (not bought offline). Just let me know if there’s any other info you need for it. Thank you.
- JohnPengMar 23, 2024NETGEAR Expert
Draco_Dread wrote:
So I have their 100gig at 80$ plan which you show as a pre-paid plan(store says they are post-paid plans since they are monthly subscriptions). The SIM card is brand new from the store (not bought offline). Just let me know if there’s any other info you need for it. Thank you.Please email your device IMEI and SIM card ICCID (the number printed on the SIM card starting with 89) to jopeng@netgear.com. I will contact Verizon to find the details. Thanks for your patience.
- calex33Apr 10, 2024Aspirant
Hello,
Same issue as described above. Was a solution found?
Model MR6550
FW: NTGX65_12.01.47.00
IMEI: 016347000069275
CA
