uknewuser
Oct 30, 2022Follower
Mobile Device
Hi I'm a complete novice, I wish to use a wifi device in my motor home. I do not want to hot spot from my fone. Once I purchase a Netgear product do I need to purchase anything else ? Is it just Pl...
Oct 30, 2022Guru - Experienced User
You can buy the hotspot but you have to have service from a provider.
Also, RV's are basically faraday cages in that they block signals because of their metal walls. Sometimes you need an external antenna on the RV to get a good cellular signal into the RV.
