midngn
Apr 12, 2020Follower
Mobile Hotpsot - Nighthawk Can It Connect To A Router To Extend The Wifi Signal?
I want to use a mobile hotpsot to be able to use a security camera in a remote location. I do have cell reception with Verizon and AT&T (Verizon seems stronger) I also want to be able to use the hots...
JohnPeng
Apr 12, 2020NETGEAR Expert
You can follow the instructions in the link below to set up your device and router.
Thanks
