reniwqwil5
Jul 03, 2020Follower
Mobile hotspot instead of home internet?
I'm looking for a good internet option for my small studio apt. I stream a lot and do my schooling online so I need a fair amount of data. Though I live alone so it will likely just be me using the wifi on 1-2 devices. I was considering using a mobile hotspot device instead of signing up with my local ISP. I was wondering what the best options in terms of price and service are. I'm located in Lexington, KY if that makes a difference.
1 Reply
You'd need to check with your local mobile providers for pricing options. If you stream a lot though, many have a data cap or charge by the gig. might not be a great option to go with if you're a streamer.
