Nighthawkm1
May 17, 2020Follower
Mobile M1 MR1100 performance
What can I do to get better performance from the M1? I can put my iPhone X in the same spot as the M1 and get 160 Mbps download and then only get 50 or 60 Mbps download from the M1? Why such a difference and what can I do, if anything, to improve this? Is the antenna or electronics in the M1 that far behind the iPhone X? When is the MR5200 coming out and will that help?
1 Reply
- Blanca_ONETGEAR Employee Retired
Hi Nighthawkm1
Welcome to NETGEAR Community!
Please provide the device SKU (MR1100-xxxx) and firmware version.
Which mobile carrier are you connected to? Is it the same mobile carrier you used on your iPhone?
Has the device already been reset to factory settings?
Blanca
Community Team
