rvtips's avatar
rvtips
Guide
Mar 02, 2026
Mobley / night hawk 1100
I have been using the Mobley and then the Hawk 1100 in my motor home for a long time.
Is there something you folks are using now that is better than the MR1100 ?
I would like something that would pick up the cell signal better.
Phil
  • plemans's avatar
    Not sure who you're responding to.
    The M6 *might* have some more speed but its more related to your coverage than it is the device. It isn't usually the device that is the bottleneck. Its the service or the coverage inside a motor home.
  • I just got the Netgear nighthawk M6 pro.
    Will have a problem going to the AT&T store to get a new sim card?
    Phil
  • thanks for the info, If I get one will my sim card work ok ?
