Skipper3
May 16, 2023Aspirant
Model LAX20 WIFI
Hi Can anyone help please: I tried many different ways to get into my router but it always takes me back to starting netgear screen with no login menu. I was advised by Netgear to change settin...
Skipper3
May 17, 2023Aspirant
Hi Micro,
I was directed by netgear support (via email) to login via http://www.routerlogin.net . Not very helpful as it went to the screen as noted in your Q1 .
I was using my pc as the netgear is right next to my laptop. I also tried the nighthawk app on my phone but could not find to get into to make adjustments to the 2,4ghz and 5ghz setting in the email from netgear:
Below are the following links:
Change channel: 2,4 GHz to 1/6/11, and 5GHz to the highest number
https://kb.netgear.com/23783/Improving-2-4Ghz-Wireless-Performance-by-Changing-Channel
Please see my comments to your questions below
What is this "Netgear screen"?
NETGEAR Router Login
Learn how to configure your router by choosing a path below.
Where do you get it? from JB Hifi
Where are you trying to log in? Browser/Nighthawk app? at home next to my netgear.
Hope that helps.
May 17, 2023Guru - Experienced User
Have you tried a different browser and/or PC?
Try using its IP address. The default is 192.168.1.1
