Emarduran
Jan 07, 2021Follower
Modem/Router recomendation
Can someone recomend a top of the line Modem/Router or router? I will start teaching zoom from home and I need the most reliable and robust etharnet/Wi Fi connection for all my systems at home. I...
Jan 07, 2021Guru - Experienced User
Who's your isp? Thats key with modem/router combo devices.
If your isp supports it, the docsis 3.1 devices are what I'd recommend.
For combo devices with docsis 3.1 theres the C7800 and CAX80 but again, you'd have to check with your isp.
You'll find most around here don't recommend combo devices. We usually recommend buying the modem seperate from the router so you can upgrade either at will as well as it gives you control over the firmware.
- michaelkenwardJan 08, 2021Guru - Experienced User
For more advice on cable modem/routers, try the appropriate bit of this community.
You don't need one of the "Mobile Routers, Hotspots & Modems" covered by this section.
