BOUYGUY's avatar
BOUYGUY
MR 1100 used as a router with IPHONE Hotspot
Greetings.
I have a MR 1100 configured as a router and would like to connect it to my iphone 13 hotspot as a source. When I connected the two together, ATT wants me to set it up with a new plan. I already have a plan for the Iphone hotspot. Suggestions?
  • Got a wired lightening/usb-c (not sure hich the iPhone uses) to ethernet adapter?
    Try hardwiring in the hotspot and enabling ethernet data offloading
    • plemans's avatar
      Guru
      the other option was did you try wifi offloading?
      page 32/33 in the manual goes over both
      • BOUYGUY's avatar
        BOUYGUY
        Thank you for taking your time to respond--I'll give Off Loading a try.
