a1966f100
Apr 10, 2023Tutor
MR 6500 ethernet
New MR6500 from AT&T. Wireless works OK but we also have an ethernet only device that we need to use. The ethernet connection has been VERY erratic. It will operate sometimes at less than 6Mbps while...
Apr 11, 2023Guru - Experienced User
Do you have it set in performance mode?
Have you tested other devices connected to it to ensure it isn't a device specific issue.
a1966f100
Apr 11, 2023Tutor
Thanks for the reply!
Yes it is set to performance mode.
I have substituted a laptop for the ethernet device we are using and I get the same problems; slow speed compared to the wireless connections, plus random disconnects requiring a reboot of the MR6500. I've got another week to decide if I need to look for another solution and at this point I'm thinking I might have too. I'm have little experience with this type equipment so if anyone has other suggestions I would appreciate the feedback. We need cellular hotspot capability, wireless and ethernet connectivity, and the ability to stay powered up 24/7 either by leaving connected to a charger or 110v supply.
- plemansApr 11, 2023Guru - Experienced User
What firmware version are you on?
Any updates available?
I've got the MR6110 but not the MR6500.
Maybe JohnPeng knows a bit more about this.
- JohnPengApr 11, 2023NETGEAR Expert
Please help to capture a model.json file and send PM to me.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backThanks
John
- a1966f100Apr 18, 2023Tutor
John, Tried to send the screen copy and got error too many characters. You may not need it. I solved my original problem by changing port setting to 2.5G and setting MR6500 display to always on. Now it has not lost internet for 4 days. Only problem now is the ethernet port is connected to an ePMP Force 180 Bridge, sending the network to an adjacent building and Internet speed in that building is slow(less than 5Mbps) most of the time. Bridge and second building setup worked much better using our previous DSL connection( in the first building) rather than the MR6500. I'm still looking to see if I can change a MR6500 setting and improve the speed. Any hints where to look? Thanks!
