vip991988
Jun 08, 2021Aspirant
MR1 1100 stuck when factory reset, can't connect wifi, ethernet.
MR1 1100 cannot connect to wifi for configuration. Maybe i remove battery when MR1 1100 update firmware Y_Y . Anyone help me to fix it ? THANKS !! ALL
vip991988
Who can help me to fix this ?
michaelkenward
Jun 09, 2021Guru - Experienced User
We don't know enough about what you are doing and where it goes wrong. So it is hard to respond.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Factory Reset.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
- Blanca_OJun 13, 2021NETGEAR Employee Retired
Hi vip991988
Welcome to NETGEAR Community!
May we please know the device SKU (e.g. MR1100-100NAS) and firmware version?
Does it affect both wired and wireless connection?
Is there any error message when you try to connect?
Was it working before?
Can you please let us know what troubleshooting you've tried?
Blanca
Community Team
