stogeyman3125
Apr 24, 2023Follower
MR100 - powers up, but can't connect wirelessly or via Ethernet. Will not Factory Reset
I have a MR1100 (Verizon service) which I used for my primary internet connection for about 1 1/2 years. It worked flawlessly during that period. I replaced it with Starlink and disconnected and powe...
michaelkenward
Apr 24, 2023Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
