jtraylorsr
Feb 24, 2020Tutor
MR100 won’t connect to my Orbi
I followed the directions for putting my MR1100 into bridge mode (select ip pass through, deselect dynamic ip, and turn off Ethernet timeout) and everything saved. When I hooked it to the Ethernet por...
- Feb 27, 2020
Super! Glad you got things working.
Rob
jtraylorsr
Feb 25, 2020Tutor
Thanks. I’ll try that!
jtraylorsr
Feb 25, 2020Tutor
I tried your suggestion but it did not help. Still can’t get the mr1100 to pass through data to the internet connection on my orbi. The mr1100 just doesn’t have the Wi-Fi coverage for my large house. Need to be able to port to my orbi. Any one else getting this to work??
Thanks,
John
Thanks,
John
- bigblue1Feb 25, 2020Tutor
Do you have an ethernet-capable device you can connect to the MR1100 to figure out whether it is the output of the MR1100 or the settings of your Orbi as the problem? Like a desktop or laptop computer? If one of those would work with the MR1100 then it's likely to be the Orbi that needs to be reconfigured. I don't know exactly what that would be but at least you can narrow things down.
You could also try turning bridging mode off and see if that changes anything.
I assume you've connected a device to the MR1100 via wi-fi already to confirm that it is actually making a valid upstream connection?
- jtraylorsrFeb 27, 2020Tutor
Thanks for your suggestion about placing a device downstream from the modem but before the router. When I did this I could get internet. I then hooked it back up to the orbi - no internet. I opened the settings on the orbi and where it was set to ppoe it had the box checked for "password required" (this was needed for my dsl modem - it was no longer needed for the cellular modem). I unchecked the box and everything worked. Thanks for your suggestion. I would have never looked at the orbi if you had not have suggested that.
John
- bigblue1Feb 27, 2020Tutor
Rob
